So the issue was battery drain. But not just the radio!!
If you have had an iPod & Bluetooth pack fitted - it might be the cause!
Turns out I had a parrot BT module with out knowing it. And it was the cause of my drain. After can bus gateway upgrade failed, we pulled the radio out to see if it was faulty. Had seen the iPod adapter module previously, but missed the BT. Pulled the fuses on them (local in the harness) and voila! No more drain!
This was probably a dealer or aftermarket fit, not factory. Apparently not uncommon, but I had no idea it was there as I'm now the third owner. I'm curious to know if any one else has seen this with the RCD 510 upgrade?
Miro from MRL automotive was exceptionally helpful in getting to the bottom of this one. Put in many hours with me. Thanks!
Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
