Results 1 to 5 of 5
Thread: Water leak in to the front passenger footwell
    Nov 2023
    Hungary
    Question Water leak in to the front passenger footwell
    Hi, i have a water leak in to the front passenger footwell (LHD car, so right side), what i tried:
    - reseat the scuttle under the windscreen
    - clean the whole tray under the windscreen
    - remove, inspect and put back all the plugs and the plastic mesh for the blower motor in the tray with silicone grease around them
    - Checked the 2 drain hole in the tray
    Water leak in to the front passenger footwell-water_leak-jpg
    After a rainy night, there was water in the hole with the red circle, and i think the water is leaking trough between the two metal sheet in the end.
    I put paper towels everywhere and in every hole, everything else above was bone dry (door seals, where the door cables comes in, blower motor, cabin filter, etc.)
    The black sikaflex was me, because first i tought thats where the water leaks in, but i was wrong.
    I tried to pour water everywhere, above windscreen, under windscreen, front right door, like everywhere but when i did everything stayed dry, no water came in.
    The leak also happened when the car was in one place so i dont think it comes from under the car.
    What else can i try?
    The car doesn't have sunroof.
    Pacific Paradise QLD
    HAs it got a sunroof
    Seems like you have done some pretty in depth testing. Have you thought about having the windscreen removed and re-attached with new sealant?
    Nov 2023
    Hungary
    I wan't to rule out everything else, because i don't think i can find a guy who can remove the windscreen in one piece and reattach it properly.
    Quote Originally Posted by Milo629 View Post
    Little update, on an another forum a member had the same issue and he managed to fix it by sealing a square hole in the wheel arch.
    Water leak in to the front passenger footwell-386466545_272287769140725_416801751118600142_n-jpg
    I also sealed it, but sadly it didn't fixed my problem.
    Mornington Peninsula, VIC
    Maybe spray the area with some UV dye or something to make it easier to see?
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
