Results 1 to 3 of 3
Thread: VW5 Golf Indicator 'clicking' not working
    Apr 2013
    Vaucluse, NSW
    Hi
    Ive got a 2004 model Golf V and the indicator clicking has stopped working, although the indicator works, and the indicator light on the dashboard does it's thing as well. VW has quoted 1600 AUD to fix this since the central electronic board needs replacement (??). I have no other issues with lights etc. Anyone able to help with ideas?
    Pacific Paradise QLD
    Quote Originally Posted by VW5 View Post
    Hi
    Most "normal" cars have a "can" which regulates pulses for the indicators but VW are bound to be different I guess The click is just the relay opening and closing in those
    Mar 2013
    Brisbane QLD
    the clicking noise for the indicators is generated by a speaker as they dont run through a relay anymore. as no relay thete is no sound so the sound is now "man made". the central electrics sends the signal to make the noise but i think the actaul speaker is in the dash panel insert. they must have tested the dash insert with final control to make sure the noise is there but found central electrics not activating it. not alot you can do. either put up with no noise or relace the ecu.. ...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
