Results 1 to 7 of 7
Thread: VW Golf Mk5 2005 TDI(BKD) rough idle when cold and cuts out
    Nov 2014
    Hi Guys
    I had an issue with hard starting a month ago and decided to change the glow plugs after an error on the Vagcom and while doing that I cleaned the EGR valve.
    Since cleaning the EGR and doing the glow plugs I have had an issue with rough idle when the motor is cold till reaching operating temperature.
    There is what seems like a misfire at low speed when cold.
    I decided to change the EGR and still no luck.
    I've read that it could be the glow plug/injector harness but wanted to check before ordering one.
    Hopefully you guys can give me some pointers.
    Thank you
    Frans
    2011 T5 Mulitivan Comfortline 103kw ,2009 Golf Tdi Comfortline 103kw,2005 Golf Mk5 GTI Stage 1 220BHP (UK),2004 Golf GT TDI 140BHP (UK),1995 Golf Mk3 GTI 120BHP (UK), 1980 Escort Mk2 RS2000(South African), 1980 Opel GTE 148Kw (South African), 1979 Golf Mk1.
    Dec 2008
    Sydney/Canberra
    You'll need to scan it, to get some sort of direction.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Nov 2014
    Hi Umai Naa
    I've scanned it over and over with no errors.
    Dec 2008
    Sydney/Canberra
    If you've got VCDS, check the missfire log for each cylinder. That should narrow it down somewhat.
    '01 Beetle 2.0
    Nov 2014
    I connected it up and there seems to be no missfire log for a diesel in the Vagcom. I tried selecting all the channels.
    Have changed the fuel filter which has made it a little better.
    Do you think it could be a temp sensor as the fan seems to come on before the car is even 1/4?
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by fransnz View Post
    Was the fuel black? / dark?
    Nov 2014
    The fuel in the filter housing was black and the filter very dirty
