Results 1 to 6 of 6
Thread: VCDS scan help for GTI
    Jan 2019
    Wentworth Point, NSW
    Hi everyone, just joined the forum yesterday.
    During the long weekend I took my GTI to Royal National Park for a happy mountain drive. Everything was smooth and beautiful there. On the way back home I tried a fast throttle and later I noticed the exhaust fault warning light was on (not flashing though). The car runs nothing but normally, at least I can't tell any different feelings for its running.
    I searched the forum and some other VW owners also had similar experiences. Some of them suggested maybe an independent VCDS scan is a good option before going to the mechanics. They also pointed out there are many members from this forum who can help do a VCDS scan.
    Therefore, I am wondering if anyone happen to have some free time that can help me diagnose what's going on with that warning light here in Sydney. I live in Wentworth Point (close to Ryde) and during day time I am always in USYD (Darlington campus).
    Last but not least, hope everyone enjoy their Oz day long weekend.
    Best regards
    Fisher
    I'm at work in North Ryde today if you want to swing past. Send me a PM
    Jan 2019
    Thx Kamold, PMed.
    Best
    Fisher
    Jan 2019
    Some updates:
    I got Julian (Kamold) help for the scan (thanks a lot mate!), the codes are
    Address 01: Engine Labels: 06F-907-115-AXX.clb
    Control Module Part Number: 1K0 907 115 Q HW: 8P0 907 115 B
    Component and/or Version: 2.0l R4/4V TFSI 0010
    Software Coding: 0403004318070160
    Work Shop Code: WSC 00046 412 00000
    VCID: 3431E21B92350C874A5-8060
    2 Faults Found:
    005699 - Please check DTC Memory of Electric Load Controller
    P1643 - 001 - - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 136536 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 03:22:20
    Freeze Frame:
    RPM: 435 /min
    Load: 44.3 %
    Speed: 0.0 km/h
    Temperature: 61.0°C
    Temperature: 27.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 11.430 V
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 136992 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:38:48
    Freeze Frame:
    RPM: 781 /min
    Load: 14.5 %
    Speed: 0.0 km/h
    Temperature: 63.0°C
    Temperature: 26.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 14.478 V
    Also these few days I drove and found some of power loss, as the acceleration is not as quick as before. Meanwhile the fuel consumption is poorer than before too. I turned off radio during the drive and found out the exhaust noise was much more than it used to be, felt like something got clogged in the exhaust pipe...
    I also discovered a horrible fact, that when car idles steady, sometimes it will give huge noise on the belts, and smokes come up from that area with a smell of burning rubber or plastic. The AC works fine so can that be a sign of dying alternator?
    Best
    Fisher
    Aug 2011
    brisbane
    while it was on a different type of car, and a diesel, i had similar symptoms. it was a faulty boost controller and split vacuum hoses. no vacuum stopped the turbo vanes from closing, so it sounded louder, and wouldn't spool up as quick, so less power. worse economy, and more smoke! could be a similar issue?
    Dec 2018
    Judging by the codes its possibly something to do with either fueling or a bad or blocked catalytic converter. I'm leaning more towards the latter.
