You don't need the scan tool.
You do however, need a VAS 6262 DSG filler, or a very good copy.
There's nothing notorious about it.
Engine off, remove the drain plug with a 14mm hex, then remove the inspection tube with an 8mm hex.
Remove the flexible section of the intake pipe after the MAF, and using a short shifter or stubby 24mm spanner, undo the filter lid, remove and replace filter.
Refit inspection tube, screw in VAS 6262 adaptor and filler hose, screw onto bottle, and rest it on the E Box/battery cover/etc.
Put all 5L in, start it up and run it for 15 mins or so, and let the excess drain out. You can stick a temp probe in the inspection hole if you wish. The target temp is 35deg C.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
