Results 1 to 5 of 5
Thread: Trunk Light Install - LED Strip
    Jul 2007
    Brissy
    So the trunk light is woeful, seriously a single 5 watt bulb to light the whole trunk, what where they smoking ?
    I purchased some cheap ebay LED strips for another project and had some extra.
    I have used a 50cm strip. 36 x 7020 SMD LED, 9 watts. You could use a lot lower spec strip and still get good results.
    10X 50cm 5630SMD Cool White Rigid LED Light BAR AL Case Milk Clear Cover CAP 12V | eBay
    The strip light I have required some assembly.
    Trunk Light Install - LED Strip-20160110_131418-medium-jpg
    The wire was only 10cm long so I soldered on a longer wire about 90cm, I used some speaker wire I had lying around.
    Trunk Light Install - LED Strip-20160110_132151-medium-jpg
    Then I marked the polarity on the wires.
    Added some double sided tape to the back of the light.
    Trunk Light Install - LED Strip-20160110_133223-medium-jpg
    Mount the light in the boot. I chose to put it up high on the metal cross member section.
    Trunk Light Install - LED Strip-20160111_182356-medium-jpg
    Route the wire behind the boot lining and around to the existing ****ty light.
    Trunk Light Install - LED Strip-20160111_182421-medium-jpg
    Now to hook it up.
    Remove the existing light, it just pulls out.
    Remove the electrical connector.
    There are probably heaps of better ways of doing this. Splicing / cutting & soldering / new connectors etc.
    I choose to simply strip back and expose a small amount of wire and push into the connector. Then tape it all up.
    The brown wire with black stripe is the earth BTW.
    Trunk Light Install - LED Strip-20160110_133759-medium-jpg
    Trunk Light Install - LED Strip-20160110_133934-medium-jpg
    Trunk Light Install - LED Strip-20160111_182443-medium-jpg
    Enjoy your newly lit boot.
    Trunk Light Install - LED Strip-20160110_194702-medium-jpg
    Trunk Light Install - LED Strip-20160110_194727-medium-jpg
    Trunk Light Install - LED Strip-20160110_194757-medium-jpg
    The light seriously shines out your trunk now.
    Total time was about 20 min including the soldering.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2011
    Simple but very effective mod!
    Any consequences of using 9W when the bulb is 5W?
    Tempted to do this, but don't want to blow fuses or trigger an error light like what happens if you don't use an error-free led bulb for the number plate lights.
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
    Mar 2015
    Quote Originally Posted by doridori View Post
    From what I recall, the only bulbs that need to be ' error-free ' INSIDE the car, are the foot-well lights. The boot light should be fine with any type of bulb, regardless of being error-free or not. Someone can correct me if i'm wrong.
    Aug 2019
    Maitland, NSW
    Either way it's less than 1 amp so unlikely to blow any fuses
    Jul 2007
    Brissy
    3.5 years, still working perfectly
    MK4 GTI - Sold
