Results 1 to 2 of 2
Thread: Tow bar wiring, TDI comfort line.
    Feb 2008
    Richmond, NSW
    Hi all,
    It's been a while since I posted here and I've done a search but haven't found what I'm looking for so here goes.
    I've got a factory fitted tow bar with the 13 pin plug and adapter to 7 pin at delivery on 05. I've used it in the past and it all worked fine.
    I know have a glider trailer fitted with LEDs and the lights on the trailer wouldn't work, all I had was some random pulsing on the side lights. The trailer lights work fine hooked up to another car and when tested.
    When I tested the car with a multi meter and a light sauce I was getting weird indications that made no sense.
    So I did as much reading as I could find and found on the Amarok page some info replacing the 13 pin plug with a 7 pin.
    So I did the swap, I found that the 13 pin plug had an earth issue anyway. With the 7 pin plug installed I've got everything working but I have faint blinking through the lights that aren't in use. Also with the lights off and the key out of the ignition the taillights/blinkers flash every couple of seconds.
    Does anyone know of a solution for the blinking/flashing with LEDs fitted to the trailer?
    Phil
    Red 99 Seat Ibiza Cupra Sport, coilovers, K&N (Gone but not forgotten)
    Blue 05 Golf 2.0 TDI DSG Comfortline, leather, sunroof.
    2012 BMW X3 MSport 2.0D
    Dec 2008
    Sydney/Canberra
    The control module for the trailer electrics emits a pulse-width modulated signal, which as you may have seen with your multimeter, is not a consistant 12.5V. This signal is sent out all the time for bulb monitoring, which is why you're getting that flicker.
    The actual problem you're facing is the control module's incompatibility with LED trailer lights. There is an adaptor for the factory harness that allows the genuine wiring kit to work with LED lights.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
