I am having hard time finding the correct sway bar bush for my Jetta.
I've measured using a paper measure, 21.5mm it says.
Using spanners 21mm is too small & 22mm has a bit of play.
I measured at the end near the link arm and in the middle of the subframe, I have not removed the bush to measure at the exact mounting point.
I can find listings for a 20mm bush and a 22.5mm bush.
So what is the correct size bush ?
Car is the FSI with the standard bar, this is not the TFSI. I'm not sure if they all had the same spec or not.
VIN WVWZZZ1KZ6M809554
