Results 1 to 6 of 6
Thread: Swapping DSG Shifter to GTI/R32 Shifter
    Oct 2014
    I've recently purchased a replacement DSG shifter that would normally fit a GTI/R32 Golf for my GT Sport which has a normal DSG shifter (worn out needs replacement). Has anybody done this conversion before? Been told that you need to heat some parts and re-orient them. Some help/pictures would be awesome !!
    Thanks in advance
    Aug 2011
    Lake Macquarie
    I did it to my TDI but when I heated the shifter pin it snapped off.
    I ended up buying a shifter out off a mk6 as they have the same front pull knob design as the mk5 gti/r32 and fitted that.
    THREAD ABOUT IT HERE
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
    Oct 2014
    Do you think I'd be able to buy just the pin separately in case I broke anything or do I need the whole mechanism ?
    Aug 2011
    Lake Macquarie
    I don't think you can buy just the pin.
    If you run into problem and need a shifter, I have just got a GTI at work so if you run into problems let me know.
    MKV Jetta FSI DSG
    Oct 2014
    Will do cheers mate
    Aug 2011
    This is what I installed (Thank you to Buckets (great bloke) for the good advice) :
    Original Audi RS6 Gear Shift Knob Audi A6 S6 4F C6 Avant RHD Car“s | eBay
    Very sporty Audi knob and no heating/twisting of plastic
