It's important that we clarify this, in case people get the wrong idea.
The stock tyre size is 195/65 R15. This has a rolling diameter of 1993mm.
Going to a 225/45 R17 will also have a rolling diameter of 1993mm. Identical. This is the best fit (the correct recommended size for the Mk5 on 17s).
Going to 235/45 R17 will yield a rolling diameter of 2021mm, a difference of 1.4% from the above sizes. This will cause the speedo to read lower at a given speed than would the 225s. As your speedometer (as calibrated from factory) is reading over by some indeterminate amount (up to 10%), this may cause it to be more accurate than before. But no guarantees.
I'll definitely be sticking with 225s.
