Results 1 to 10 of 13
Thread: Suspension recommendation for modest lowering - Mk5 Comfortline
    Nov 2009
    Hi guys,
    Apologies for creating yet another suspension recommendation thread, although I haven't found anything discussing specifically what I'm after, so I thought it best to post a new thread.
    I have a stock-as-a-rock 2005 Golf 2.0 Comfortline, running boring 15s. I'm planning on fitting a set of 17" Denvers in the next few months, but really don't want the car to look like a 4x4.
    Specifically, I'd like to replace the suspension with something that will give me roughly OEM GTI ride height - or maybe ever so slightly lower. I really don't want to slam it, and don't want any rubbing issues. I also don't want anything that's going to bang or knock, or require ongoing maintenance - again, OEM+ is my aim here. Ride quality is important - I don't want something that's rock hard or underdamped, although firmer than stock is okay within reason - this is my comfy slow everyday car. I don't want handling to be rubbish either, but this is a lower priority for me (I assume any aftermarket option will improve on the stock handling, and besides, I have an S3 for handling duties).
    So, with the above in mind, what would people recommend? I don't have a specific budget in mind, but don't want to go overboard.
    I've read that the HPA SHS Coilovers are made for the Mk5 (inc. non-GTI?) and seem to be highly recommended, although I'm not sure whether they'll lower the car too much (even at their highest point), and they certainly aren't cheap. But if they're my best option then so be it.
    Thanks for any advice or suggestions!
    Jun 2013
    Height adjustable coilovers for non-GTI Mk5 for $500 shipped:
    Mk5 Golf FK Coilovers | DUB TUNED | Australia
    Google reviews for Fk Streetlines
    Nov 2009
    Quote Originally Posted by swong View Post
    These are good value (read: insanely cheap), although reviews I've read suggest that they've got a poor ride, and are prone to clangs and bangs as well. I also don't need what they seem to be used for predominantly - a slammed ride height. So not exactly what I'm looking for.
    Going off WhiteJames' very old (2009) post, "HPA KW SHS coilover height only adjustable kit imported from HPA for @ $1700 - $1800 is the best I've sampled for a daily driver comfort/sports suspension system". I'm just not sure of any more appropriate alternatives (e.g. stock GTI springs and dampers, if available?).
    Erskineville, NSW
    If you go to 17" with OEM sized 225/45r17 tyres there is no meaningful difference in overall diameter & therefore there will be negligible difference in the hub to guard standing height or even the distance from the top of the tyre to the edge of the guard.
    Any difference you discern is a visual anomoly based on the change of wheel to tyre size balance.
    If you want the tyres to look like they are filling the guards a bit better then fit 235/45r17. It will cure the inaccuracy in your speedometer at the same time.
    If you want it to have the same visual impact as a GTI then buy a 2nd hand set of GTI springs (they are worth almost nothing) and fit them to the stock dampers (unless the dampers are stuffed as well).
    Or buy quality coilovers. I think the cheap sets will disapoint.
    Nov 2009
    Yep, agreed Brad - the differences are all psychological / visual tricks. Of course it still looks terrible on 15s now, and that's not all down to the small rims.
    The stock dampers are fine (the car's only done 47,000km). Are GTI springs a straight replacement on the FSI? I was of the understanding that there are differences in geometry (albeit minor) that may leave the car sitting not-quite-level. I also wonder whether fitting GTI springs will shorten the life of the dampers?
    Of course I'm sure they'd be a whole lot cheaper than a set of the HPA KW SHS coilovers...
    Erskineville, NSW
    GTI springs in the Comfortline will fit straight in and be fine if it has the 55mm struts (I'm not sure how big the spring seats are on the 50mm struts but they are probably the same). If you are DIYing it would be a good starting point to get an idea of ride heights.
    Yes, any heavier spring will shorten the life of the OEM damper but not significantly. You'd probably get another 30k out of them.
    I'm not sure what you mean about not sitting level but if the 2.0FSI lump is lighter than the GTI lump then it might be a fraction nose high.
    If you are paying for somebody to stuff about then it oisn't worth it, if you DIY then all it costs is time.
    Oct 2014
    why don't you just try and find some GTI coilovers off a wrecked GTI?
    Nov 2009
    I read somewhere that cars under 120hp (ie 1.6l) used the 50mm strut, and the remainder used the 55mm. I've not confirmed that though, and haven't measured up my car yet.
    This won't be a DIY job for me; I have neither the tools nor the expertise unfortunately.
    Mar 2015
    I'm also about to replace my stock 15" with 17" classix and was going to get 225/45/17 tyres, if i get 235/45/17 as you say, would there be any downside over the 225's? (Sorry my tyre fitment knowledge isnt that great)
    Ps; this is on an 06' 2L tdi comfortline
    Sent from my SM-G900I using Tapatalk
    Erskineville, NSW
    upsides
    235s are usually a bit cheaper
    Speedo will be more accurate
    Guards will look more filled
    Ride will be slightly softer
    downsides
    You won't be able to lower it into the weeds (but won't need to)
    turn-in will be slightly doughier at the limit (but most people wouldn't notice)
    I can't think of anything else but maybe someone else can add.
