Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: SuperPro Supaloy Control Arms
    Dec 2008
    Perth, WA
    Hi Chaps -
    Anybody tried these out on their Mk5's yet?
    SuperPro Supaloy Control Arm for VAG - The full story - YouTube
    They look interesting. I'm guessing most of the improvement is from the stiffer bushings..
    Anybody run them?
    Cheers.
    Nov 2009
    SEQLD
    I've got them on my mk6. Big improvement! Steering feels lighter and turn in is so much sharper. Also about 2kg weight saving per side over oem.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Dec 2008
    Perth, WA
    Quote Originally Posted by Brendan_A View Post
    Easy enough install job? Do you need a wheel re-alignment done (ie can be it be done at home?)
    How much did they set you back?
    Cheers.
    Nov 2009
    SEQLD
    I had my VW specialist instal them. 1.5hrs labour. The gearbox has to be lifted a little to get the front bolt out on the LH lower control arm. RHS is easy as. If you have a hoist at home it would be ok to install at home. Yes you need to get a wheel alignment done after installation.
    I got mine from this ebay seller for $520 shipped. VW MK5 MK6 GTI GOLF R Audi S3 Arm Super Pro Lower Control Arms & Anti-lift Kit | eBay
    MY20 Golf GTI TCR
    Aug 2011
    Thinking of getting a set of these too.
    Did they make the ride comfort different at all?
    Nov 2009
    SEQLD
    Quote Originally Posted by lankfert View Post
    No different in ride comfort just big improvement in handling!
    The build quality is top notch too.
    MY20 Golf GTI TCR
    Dec 2008
    Perth, WA
    Thx..
    I presume if they're lighter they're made from a different material? Aluminium? No reliability/toughness issues? (My car gets driven real hard)...
    Cheers fellas.
    Quote Originally Posted by kryten2001 View Post
    Hi Chaps -
    Anybody run them?
    Cheers.
    Looked at those too, but then decided in favour of OEM AUDI S3 kit. Aluminium as well with stiffer OEM bushings.
    Will do those when my chocks are due... 100K on the now, getting close
    .:R32T, Stock Internals | C2 stage III hardware | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler
    Jan 2008
    Sunshine Coast
    Very interesting!! What makes the dearer Audi ones better, do they allow more caster adjustment??
    Nov 2009
    SEQLD
    Thx..
    Cheers fellas.
    They are made of aluminum. I've only had mine on for 1500km. I guess they would bend if you hit a solid object at speed just like the oem arms would.
    Guy Harding uses these on his Golfs. So they must handle track use fine
    The new rear bush adds up to 1.5deg positive castor.
    MY20 Golf GTI TCR
