Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: SuperPro Supaloy Control Arms
  1. #51
    Jul 2010
    Glen Waverley
    Hey donweather what were the characteristics during driving with the failed bush.
    GTI MKV, 3 pedals >D, black, leather, K04 APR tune , APR RSC tbe, BSH CAI, Bilsteins sports shocks, H&R sports springs, wavetrack LSD, H&R sway bars, and painted that stupid looking matt black plastic bumbers and side skirts to match the paint of the car
  2. #52
    Oct 2009
    Mitchelton, Qld
    It's discussed more here Phil.
    Front End Problem
  3. #53
    Jul 2010
    Glen Waverley
  4. #54
    Jul 2010
    Glen Waverley
    Mmm I am starting to get the exact same characteristics, steering feels vague, hear a clunk when I am going slow over bumpy road and car feels like it floats, also getting some serious axle tramp, stock was better, will jack up the car this weekend and check the bushes as well. When did you install your alloy arms? I had mine installed in July 2012 i wonder if mine had the old design bush.
  5. #55
    Oct 2009
    Mitchelton, Qld
    I got mine installed just over 12 mths ago (late August 2013).
    If you can't get the car up on a hoist then you can still see the wheel move just from rolling the car forward and back and braking. You'll see the wheel move relative to the wheel arch when the car brakes (standing observing from the side of the car).
  6. #56
    Jul 2010
    Glen Waverley
    Cool will give that method a go
  7. #57
    Jul 2010
    Glen Waverley
    Epic thread bump.
    Well the rear bushing was the culprit both got replaced under warranty
  8. #58
    Feb 2014
    Melbourne, VIC
    I have personally been involved in the development of these arms from day 1, so might be able to add a bit of insight?
    The arms are imported, they are an OE casting & they come in the "bright" coated finish, they are not polished at all.
    The bushes are cast / poured into the arms in Moorooka, Brisbane.
    The design of the rear bushes is similar to other "made in Asia" Gold & Yellow "Anti Lift Kits", they add approximately 1.5 degrees of static castor.
    Unlike the "Anti Lift Kits" listed above, we don't have bushing failure due to the high lateral forces splitting the rear bush. There were multiple design changes to overcome this, and all tested on our APR Australia cars on the track & street. An example of the testing is some versions of "Anti Lift Kits" wouldn't last 20 laps of QLD Raceway with braking forces of the National Circuit. They have also failed on VAG cars competing in Targa Tasmania.
    There are now also adjustable ball joints that work specifically with these arms that allow us to achieve an extra 1.5 degrees of negative camber.
    These ball joints are included in the Harding Performance version of the arms (RR $750).
    Summary:
    They are an OEM VW / Audi arm, they are not "polished"
    They do have "Anti Lift" bushes in the rear
    They do have harder bushes in them so you may experience different noise & vibration to stock arms
    They have harder bushes in them, so you do get better feedback & response.
    Like all suspension changes, a good wheel alignment is critical, you can throw all the suspension parts you like at a car, and be let down badly by the wheel alignment.
    Hi Guy,
    Reviving an old thread here but was wondering if the Superpro Alloy Arms are much of an upgrade over TTS stock arms which I believe are already alloy (and some people seem to use these as an upgrade on Golf's).
    The weight saving would be less or non-existent but do you still get camber and caster advantages?
    Thanks,
    Craig
  9. #59
    Hi Craig,
    On a TTS the only real advantages would be more rear castor & a pivoting bush. There may be more camber available from the balljoint but I have never confirmed on a TTS.
