Results 1 to 6 of 6
Thread: Sway bar in Brisbane?
    Sep 2012
    As suggested, anyone no where to buy and/or install sway bars in Brisbane?
    Current - 2015 Tiguan 155 R-Line.
    Previous - Jetta MkV 147 Turbo, Viezu Raceday mapped, Carbonio CAI, Quad Exhaust System, R8 Coil pack, Whiteline Swaybar, GTi Steering wheel with paddles, Alloy pedals, RNS510 & Leather.
    brisbane
    install; i'd recommend prestige and performance.
    buy; may be ebay? a store on there sells whiteline gear and is brisbane based.
    brisbane
    ps if its the rear sway only it should be a slice of urine to fit yourself and save a few quid.
    depending on when you are planning on installing, i may be able to give you a hand if you like...
    Jan 2011
    Brisbane - QLD
    We have SuperPro headquarter here in Brisbane.
    Brakesdirect.com.au / GSL Rally Sport sells Whiteline sway bars too.
    Rear sway bar install is super easy.
    Front.... i have been quoted $390-$450 just for the install excluding alignment here in Brisbane / Gold Coast. Alignment is extra $100-$120.
    In Sydney, it costs around $350 fully installed and aligned for both front and rear by a reputable shop. Back then when I was in Sydney I was quoted $300 for front and rear install but I did not go ahead thinking I would try having the rear on first..
    My new H&R front sway bar has been in its box for the last 2 years plus
    I am contemplating a DIY (but a hoist access will make life a lot easier!) but will give another mechanic a try for a reasonable quote first.
    It seems to be a big job (or so they say) by some mechanics. Not so by those who do know how to do it and have done it many times. In fact I rang another independent VW mechanic in North Brisbane today and I was asked why (why installing a different sway bar?).
    Some resources I have compiled:
    Volkswagen Workshop Manuals > Running gear, axles, steering > Front suspension, drive shafts > Subframe, anti-roll bar, suspension links > Removing and installing anti-roll bar
    MINI Cooper S Clubman - FWD
    Mar 2013
    Mid North Coast
    Hi, i have a jetta and just kept an eye out for a second hand rear bar from a gti, got it for fifty bucks and put it in myself, its easy to do and made a nice improvement
    07 Jetta Tdi, DSG(tuned),Gtb1756vk turbo, 3inch dump, Malone tune, 4bar map, EGR+EGR Cooler delete, S3 Intercooler, Hard pipe kit, Gti rear sway bar, 18x8 Enkeii gtc01, nitto tyres, Rear Lip Spoiler, Votex Front Lip, Slotted and drilled rear Discs, Neuspeed springs, LED interior lights, Blackened window trims, Carbon covered pillars, Gti lower front Grill, canbus update, rcd510, tinted indicators, gti paddle shift wheel, soon to have Votex Side Skirts, Coilovers, Porsche Brakes,8mm wheel spacers, Alloy control arms, GTI front sway bar, S3 bushings....
    Sep 2012
    thanks folks, might be my next project....have seen them on Ebay for $250
