Results 1 to 9 of 9
Thread: Sunroof & Windows Malfunctioning
    Mar 2014
    NSW
    Hi Guys,
    Has anyone experienced with their sunroof open and close by itself? Sometimes my windows open by itself as well. Very strange.
    Does anyone know what the problem is?
    Thanks
    Henry
    NSW, Sydney
    Best place to start would be to scan the car on VCDS for fault codes Henry.
    You're more than welcome to bring it over to mine and I will scan it for you.
    Apr 2015
    Brsbane QLD Australia
    Are you by accident holding down the remote button....ie in your pocket etc..
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
    Mar 2014
    NSW
    No i was driving and i can hear the sunroof open and close.
    Jul 2011
    If your driving and its operating on its own Check all your connectors and then possibly replace CCM
    May 2011
    Yeerongpilly, Brisbane, QLD
    How old is your battery? Some weird things happen when the battery is on its way out
    BMW Z4 (2019)
    Audi TT quattro (2015), s-line in Nano Grey - sold
    Jan 2011
    Adelaide SA
    Quote Originally Posted by vw888 View Post
    Hi Guys,
    Thanks
    Henry
    Our sunroof opens (tilts) by itself. Usually when cruising along the Expressway or just tootling along at 60ks Never closes itself. Doesn't slide by itself. Turn knob to open then back to close and it closes, only to open again a day or so later?? Windows behaving OK so far.
    Dec 2008
    Sydney/Canberra
    Check your driver's door wiring harness, where it passes from the door and into the A-pillar. Just pull the rubber boot back as far as you can, and check for broken wires.
    I'm almost certain something to do with the sunroof is in that harness, and goes back to the driver's door control module.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2011
    Adelaide SA
    Quote Originally Posted by Umai Naa!! View Post
    If It wasn't a VW I would think you are having a lend of me Umai. Yet VW logic says you are right, why would a sunroof with the controls on the roof just in front of it not have wiring going into the drivers door?? Pity VW chose to use wire which hardens and breaks after a few hundred cycles. One in the tailgate broke and the others there are quite stiff.
