Results 1 to 4 of 4
Thread: Sticky windows
    Sutherland, NSW
    Sticky windows
    I have a Mk5 golf and a couple of the windows are starting to get very slow when going up and down, and i think it's time to lubricate the channels - one of them has a 50% chance of the auto-close failing even after adaptation.
    I've done some research and it seems the correct product to use is a PTFE paste that my local dealers don't have and one of them suggested lithium grease, which i think is a bad idea.
    I'm guessing since the genuine product is PTFE it's free of silicone as well, so it' a dry product that won't attract dust and lithium grease is anything but dry.
    Bunnings has a WD-40 brand ptfe spray product that looks good, is there anything else suggested?
    Is gummi-pfledge usable as a lubricant? i thought it just softened rubbers?
    Thanks!
    matt
    Dec 2008
    Sydney/Canberra
    The rear doors had a software update for the auto-close.
    I've used silicone on the bailey channels in the past with no issues. I don't believe it's viscous enough to catch grit.
    Sutherland, NSW
    Ah, thanks for the help, i used silicone and they are moving quite a bit faster now!
    Should i ask VW to check that the auto close update has been applied when i get it serviced next? is there a special name for the update that you know of?
    Thanks!
    Dec 2008
    Sydney/Canberra
    I remember seeing it in a tech bulletin about 6 years ago.
    Easiest way from your end, would be to tell them what it's doing and hopefully they'll get it sorted without too much trouble.
