Originally Posted by
Rob Burns
I'll amend it then.
If you change your oil before the 1 year/15k mark and VW Australia find out about it then you will void your warranty on the engine.
Are you sure about this?!
I highly doubt it...
I have changed oil / filter on previous VW's and have never had an issue with servicing or warranty.
Maybe if you put a non approved / wrong grade of oil in that does not meet manufacturers specs, that might contribute to engine damage, fair enough. For example, by not using a 507.00 in the newer engines (such as TDI's with DPF).
I would like to know where you have sourced this info from Rob.
