Results 1 to 2 of 2
Thread: S3 Rear brakes on Mk5 GTI issues Help?
    Jul 2017
    Hi everyone I currently have stock brakes on my 2008 MK5 GTI.
    I got a set of rear discs from a Performance Pack GTI 40 year edition.
    I also bought a set of S3 rear Calipers with the carrier so the rest of what I needed.
    When fitting it all up I found that the pads from the performance pack gti were different to the S3 rear calipers so I had to buy new pads that fit the s3 style calipers.
    Now the problem I have is that I put the discs on they fit but touched the heat shield so I pushed that back a little as it was only short by a few mm. Then when i tried to put the brake carrier onto the hub and over the disc I found that the carrier was touching the disc and wasn't even flush with the hub to mount it.
    So either the Mk7 rear discs are a different to the s3 rears discs that fit the mk5 gti. I would assume that this is the case but I haven't been able to find anything that says what offsets the mk7 is compared to a mk5 or if its all the same.
    Anyone else done this conversion and can shed some light please ??
    Aug 2011
    Lake Macquarie
    MK7 brakes are different to MK5/MK6
    MKV Sportsline Soot Belcher
    MKV Jetta FSI DSG
