Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Rough idle
    Oct 2010
    Thanks for all the info guys! Im not the most mechanically minded person, so I wouldnt have a clue how to change it, but ill see what VW says when I leave them my car and if they quote me something ridiculous, I might consider trying haha
    2008 Metallic Black Jetta TFSI
    2001 Pearl White Toyota Crown Estate
    Mar 2007
    Hobart
    JimmyH, did you get this issue resolved? My 2007 GTI is exhibiting exactly the same symptoms.
    2018 Golf GTI, Manual - gone.
    2017 Golf 110tsi Trendline, manual (gone - gladly)
    2007 Golf GTI, Manual, (gone - sadly)
    1978 Golf GLS; 1972 Superbug, (memories)
    Oct 2010
    Sure did! It was the PCV as most people said =)
    Mar 2007
    Hobart
    This is good info - means I can go into the dealer informed.
    Oct 2009
    Yep. Had mine replaced today.
    Mar 2007
    Hobart
    Ditto, mine replaced and car is running as smooth as a baby's bottom again. Feels gruntier, too.
    My report said "...found a code for engine running lean and intake air leak. Checked and found the oil breather valve was at fault."
    I assume the oil breather valve is the same pressure control valve of which we speak?
