Is your phone paired with the BT module again after you reset it?
Hey guys, so I recently bought an MKV R32 that came with the RNS510 and a 9w7 Module under the driver's seat. It did show the bluetooth option in media the day I got it so I didn't think too much of it. But after resetting it to factory settings, It has since disappeared from any menu. I can't for the life of me figure out how to connect it to my iPhone 6 (the manuals didn't help at all) or any phone for that matter.
I'm not sure if the models of the RNS510 (1T0035680 L) or the 9w7 (7P6 035 730 M) come into play here, since I can't find anything on this combination. It also had a OEM ipod adapter installed if that matters, but I unplugged it for the AUX port since I don't want to get a 30pin to lightning adapter. Another thing I realised was that the pins for the AUX and iPod connector weren't correct for the RNS510, so I had to repin ground and right channel(?) on the connector for AUX to work again. I'll open up the dash again soon to have another look.
Any pointers will be great!
Got it to work again.
It wasn't showing up in bluetooth settings for the phone regardless if the car was on or off, so I replugged the connections and checked again. Surprise surprise it showed up on the phone and paired again. Not sure what the issue was specifically because everything was wired correctly (at least from what I could see), maybe a loose connection? or a glitch in the coding?
Glad it fixed itself though.
Good result![]()
