Results 1 to 6 of 6
Thread: reversing camera
    Jun 2009
    acacia ridge qld
    Question reversing camera
    Hi guys
    Have an eonon D5152 fitted to my 2007 vw Jetta .Have wired up reversing camera .When ignition on and engine not running picture on reverse camera is fine. But as soon as engine started picture in reversing camera starts rolling. Any suggestion of how to fix this problem.
    regards Barrie
    Mar 2013
    Brisbane QLD
    Sounds like some sort if interference....may be ask the supplier of your camera if know issue...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    brisbane
    i had the same issue with my s3 mate, are you taking the power from the reverse light? afaik the reverse light power is a pulsed signal, hence the flickering...
    try taking power from a 12v source wired from the ignition, this should hopefully fix it. it worked for me, good luck...
    Jun 2009
    acacia ridge qld
    Thanks for that. Yes am taking power from reverse light .will try the power socket in the boot .
    Jun 2009
    acacia ridge qld
    where did you pick up power wire from .tried power socket in boot and camera stayed on all the time even when not in reverse.any thoughts
    regards Barrie
    Nov 2010
    I think youll find that the socket in the boot is constant 12v, hence why its on all the time. When i installed mine in my R36, i actually used the reversing trigger wire to trigger a normal relay which i set up so that the power was coming from a stable source. It is just a matter of running wires. I was lucky enough to have the battery in the rear which made it even easier. Best of luck
