The issue with putting in a newer generation head unit into a car earlier than around 2008 is that there is a network switch, known as the CANbus gateway that in newer head units cuts power 30mins after shutdown.
This allows the head unit to start instantly if you go into the service station to pay, instead of going through the whole bootup sequence (which in an older RNS510 can be a bit lengthy).
So if you have an older gateway that doesn't shut the head unit down after the car is turned off, it will quickly drain the battery.
If the car is pre 2008 (you can actually check the gateway part number and if it ends in L or later then it's OK) then you will likely need to upgrade the gateway.
