Results 1 to 7 of 7
Thread: rear headrest removal
    BRISBANE
    having only owned japanese cars in the past that come apart a pretty easy and aussie ones where they fall apart i have been deeply confused by the rear headrest on the gti is there a button other than the adjustment release to remove the headrest all together ?
    Can get it to the top but can't remove it, just to make adjusting the capsule strap easier.
    thanks
    http://www.vwwatercooled.org.au/image.php?type=sigpic&userid=33978&dateline=129447  61752008 Candy white GTI DSG - 1990 mx-5 loud, rough, uncomfortable but still an amazing car
    Nov 2007
    Quote Originally Posted by adamk View Post
    Can get it to the top but can't remove it, just to make adjusting the capsule strap easier.thanks
    Is it the centre one? Mine seems jammed too - I can get the other two out easy the middle one just slides all the way to the top- the button on the side of the slider doesn't seem to do anything.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    Jan 2008
    thanks
    The outer ones remove but the centre one is not designed to be removeable.
    Nov 2009
    thanks
    I think what you are looking for (for the outer ones only) is on the pole opposite to where the headrest release button is there is a tiny rectangular hole which you need to push a paperclip in to release the other pole.
    Volvo S60 RD T6
    BRISBANE
    i knew the germans would have put in that extra level of engineering over the when it gets to the top it falls out version
    Nov 2009
    Perth, WA
    Feb 2010
    Brisbane, Queensland
    I never had this issue until recently, which left me thinking the centre headrest was broken. Here is another link with more pics -
    http://www.golfmk6.com/forums/showthread.php?t=34784
    instead of shopping for a cap with pusher, I turned the 'pushless cap' anti clockwise, and left insitu. There is enough room between seat-back and head rest to raise cap-to-depress the (hidden) pusher.
