Results 1 to 5 of 5
Thread: P0401 code every 100 miles
    Oct 2017
    London
    Hi
    It is a 1.6 FSI petrol BLP engine.
    Replaced the EGR valve with a Siemens EGR valve. Cleared error code. Tested OK.
    Drive the car and after about 100 miles the code is generated again.
    Cleared the code and later it is generated again.
    Any ideas?
    Jan 2013
    Brisbane, QLD.
    Have you confirmed wiring is good?
    Oct 2017
    London
    Quote Originally Posted by The One View Post
    Hi
    Thanks for the quick reply.
    No is the answer. The car mileage is not high, so I assumed the wires will be OK.
    But, how would a longish run be connected to the wiring ?
    Dec 2008
    Sydney/Canberra
    The car needs to go through a drive cycle.
    If the values aren't correct, it will log a code.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by vwfan3 View Post
    Hi
    EGR valve opens and closes at certain times, how do you know it's working correctly @ the correct times if you haven't checked wiring? Just because the code relates to the valve, does not mean the valve is faulty, this is called poor diagnosis. Have you even confirmed correct function of the other parts of the EGR system?
