If your car is a 2009 model, it sounds like you have the last of the Mk5 model just before the Mk6 was released. The Mk5 and Mk6 are very much the same car (same chassis, suspension, same engines in some models - although the Mk6 GTI engine was different to that in the Mk5 GTI). Externally the cars look different (bonnet, bumpers, headlights etc) as well as the interior (dash etc). I believe the roof is the only external body part that is shared between the Mk5 and Mk6.
The Mk5 GTI had the exhaust exit on the passenger side with 2x tips whereas the Mk6 GTI had one tip out each side. If you wanted to have the Mk6 exhaust setup on your MK5, you would need to buy a Mk6 GTI catback exhaust, and then either modify your current rear diffuser to allow the 2nd pipe to exit on the drivers side, or purchase an aftermarket diffuser with the dual cutouts.
