Results 11 to 20 of 30
Thread: New wheels Finally chosen, now to pick the colour.
    Feb 2008
    Gunmetal on white
    New wheels Finally chosen, now to pick the colour.-r36-jpg
    CR Audi RS3
    PW Golf 7 GTI
    Not sure of your brake setup but if you're worried about dust you could try ATE ceramic pads. Transporter installed them on my car (with silver wheels) and there's nothing there after a few months - mostly road grime/oil/dirt not the usual black brake dust.
    Erskineville, NSW
    ^^^^^ this!
    Fit some low dust pads.
    Give the wheels several coats of sealant.
    problem solved
    Jul 2010
    bracken ridge qld
    ^^^ have to agree.i am finding the ATE Ceramics the best answer to that dreaded brake dust.
    cheers
    warrick
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Mar 2008
    Brisbane,QLD
    where can I source ATE ceramic brake pads?
    Erskineville, NSW
    HSY are the australian importer / distributor. They should be able to point you to a retailer
    Jul 2010
    bracken ridge qld
    May 2013
    In order to combat the brake dust, I did fit ceramic pads on my rears at the last service (they were due for replacement anyway). I still run stock pads on the fronts as they had plenty of meat left on them. There is no clear difference between the dust levels between the fronts/rears.
    I read somewhere that the discs also play a part in the dust levels as they are designed to wear with the pads. Apparently this helped with cold weather braking performance in northern Europe.
    MY08 Mk5 GT Sport - sold
    In order to get the warranty on the ATE products you need to get new pads and discs at the same time - I'm sure this would play a role in minimising the dust too as the pads and discs would be designed to work optimally together. I too have stock ones one the front and ATE on the back and the difference is night and day.
    Oct 2009
    Mitchelton, Qld
    they never replied to any of my emails when I contacted them.
