The blue bit needs to be pushed in.
It is a tight space, remove the black plastic mounting strap and you may be able to get a better angle on it.
If you want to reduce the amount of fuel spilling, run the engine and pull the fuse for the fuel pump, wait for the engine to stall.
How to Install A MK5 Volkswagen Fuel Filter - YouTube
