Results 1 to 5 of 5
Thread: N249 Valves - Are they all the same?
    Jan 2011
    Hi internet car friends,
    I have a 2008 GT Sport TSI. Recently it has been exhibiting symptoms of N249 failure. Replaced the N75, but that didn't fix it so I sent it in for a checkup and the mechanic confirmed from the fault code that it is indeed an N249 failure.
    He seems to be unsure of the difference between N75 and N249, so he insists that it is impossible to just replace part of it. Seems a simple part to replace so I was thinking I might just get one from a wrecker and put it in myself.
    My question: Is there any difference between the N249 part used in a standard MK6 and the one currently in my car?
    Thanks.
    MY09 Golf GT TSI
    May 2013
    It's a valve and a solenoid. IIRC the N249 was updated with a newer part number to fix it and stop it failing (as was the N75). You need to make sure that the one you get is the updated design.
    MY08 Mk5 GT Sport - sold
    Jan 2011
    Are they sold as seperate parts?
    MY09 Golf GT TSI
    Perth
    Quote Originally Posted by semiotech View Post
    They sure are, from memory the N249 is ~$90 and the N75 ~$130?
    Some more info here if you like: No turbo boost when car is warm (1.4TSI)
    MY08 Blue Graphite GT TSI DSG
    Jan 2011
    Having the same problem you did. Hopefully the N249 replacement will do the trick.
    MY09 Golf GT TSI
