Results 1 to 2 of 2
Thread: MKV GTI + RCD510 Powerdrain Issue unknown solution! Should be a Sticky!
    Oct 2010
    Perth, WA
    Dear All
    After months and months and large amounts of $$$ of trying to work out why my 2005/2006 MKV GTI was experiencing power drain issues following the installation of a RCD510 I have finally found a solution. I changed the gateway, reprogrammed the gateway, used a multimeter to measure draw, removed fuses and nothing worked. Finally a very smart person from the UK solved my problem. Early GTI's have a Amp under the passenger side seat and any car that has this and the sound system installed will NOT experience 'power drain' after installing a RCD510. I ended up putting back my original gateway and this solved the problem. I went on holidays for 2 weeks, came back and everything worked fine.
    Please make this a sticky!
    More information can be found here
    RCD 510 and CANBUS upgrade but still Powerdrain
    Apr 2008
    Nothing better than when sleuthing gets it done.
