Results 1 to 3 of 3
Thread: MkV GTI fans
    Oct 2013
    MkV GTI fans
    There was a squeaking noise on my car recently and occured when starting the car and staying on idle. I changed the timing belt but its still there.
    Is it the radiator fans? I heard they are expensive to change?
    Mar 2013
    Brisbane QLD
    could be your pressure valve...try removing your oil filler cap with the engine running...if it doesnt come off your pcv valve is buggered...causes a sqeal noise running and will hiss for a while when you turn off the engine
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Aug 2007
    It can squeal after shut down, liken it to a balloon full of air being let out slowly. Only happens when the diaphragm just splits, when fully busted itll run bad anyway
    Alba European
