I'm looking for a wiring diagram for our MkV 2.0 FSI BLR specifically for the Ignition coil-cam angle sensor-ECU circuit in order to diagnose an ongoing crank but no start problem (see:Vacuum leak help). I've tried searching via google for days and found workshop-manuals.com but I find the navigation extremely difficult and just can't find what I need. Can someone with more experience send me a link to what I'm looking for, either on the above website or somewhere else? Here's the workshop-manuals page for the car:
Volkswagen Workshop Manuals > Golf Mk5 > Brake systems > Technical data > Brake allocation via PR No.
Also can someone tell me where the cam angle sensor is located on the engine so I can check/test the connector? Thanks.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Yes same engine layout - thank you. Do you also happen to know where the cam position sensor/ignition coils plug into the ECU? Is the connector near the ECU box under the wiper cover or is somewhere else that I can check without uncovering the ECU itself?
