Originally Posted by
kamold
Not really that straight forward. VR6 bell housing is different to inline 4/5.
Needs custom bell housing and flywheel.
You'll need to modify the TCU software on the new gearbox also as it won't be setup properly for the engine, and may also possibly need some CAN messages modified.
DQ500 is a bigger job again requires starter motor, drive shafts, custom modified bell housing, flywheel, shift adapter, require TCU plug and of course custom TCU software.
Best advice is talk to a shop thats familiar with these swaps as there are lots of potential pitfalls.
Might be better to rebuild your current gearbox, maybe with a mechatronics upgrade to a newer revision - what is the actual issue?
