Mine was doing very similar things. A new starter motor and it starts like a dream hot or cold!
The battery is a Varta 70Ah 680cc i am about 99% sure. I tested it 12.7 ignition off. 12.4 ignition on. 14.4v idle. I know this does not reflect voltage drop, but when I had someone cranking the engine over while i was holding multimeter on the battery the lowest that I saw was roughly 10.8v which i believe is still good.
The wobble is probably best described as feeling like a wheel is wobbling. Apparently the inner cv joints on this model are prone to failure and that is what has happened to mine. Mechanic also things it maybe the trans and engine mounts contributing to the rough start as the engine is allowed to move too much when cranking. He is not ruling out the starter until he gets a look at it on VCDS
Thanks so much for your help.
Hey Steve,
Where did you pick the starter up from and how much was it? It seems that watercooled parts suppliers in Aus are hard to come by...
Thank you for you input. This thread may eventually help someone else out one day.
Hey I was having a very similar problem with the wobbling and the shaking at low rpm, but I also had a rattle noise coming from the back of the motor. Had it looked at, was told it's the engine mount so got it fixed but the noise and shaking didn't go away. So after close inspection found out it's the dual mass flywheel exactly what I didn't want not the cheapest repair getting it done now get it back on Tuesday hopefully. Mine has 156ks and I was told they go between 150-180xxxkms hope it's not your flywheel.
shaking has been sorted. it was the engine mounts and inner cv joints. have been living with the starting issues.
try disconnecting the coolant temp sensor
which one is that?
Sounded like mine. I replaced my starter motor and it works fine now.
