Results 11 to 20 of 40
Thread: MK5 TDI rough start issue
    Dec 2014
    St Clair, NSW
    What's your location?
    Sorry I am in Sydneys West. Near Penrith.
    Dec 2014
    St Clair, NSW
    Quote Originally Posted by The One View Post
    DSG? Always a good idea to remove starter motor and inspect DSG flywheel. They usually get loose after awhile causing excessive movement on startup causing hard start problems, shaking/hesitation/jerking etc.
    Also note that you will probably have a G70 crankshaft sensor fault, which will most likely be due to trying to start it over and over (dont overlook it) but just make sure it's not logged because you've been trying to crank it so long, as opposed to it actually being faulty.
    i hope it is not the flywheel i don't have a scanner to check for codes. any other symptoms i should look for to confirm the flywheel is to blame?
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by kaiisons View Post
    Not really, if you absolutely cannot fault the issue (i.e: using logistic diagnosis and ruled out every possibility) then it's time to pull the gearbox and check the flywheel by hand for excessive movement..
    Dec 2014
    St Clair, NSW
    that is beyond my capabilities. anyone that you can recommend in western sydney area?
    Jan 2013
    Brisbane, QLD.
    Not to sure of anyone in Sydney, sorry. But don't be scared just yet, get a logical diagnosis going, it could be something simple. I am just advising on the DSG flywheel possibility because I have seen them cause this issue many times before, this does not mean this is your issue, just a possibility. Remove the gearbox to check the flywheel as a last resort .
    Dec 2014
    St Clair, NSW
    thanks for you help. will keep it as a last resort.
    Mar 2013
    Mid North Coast
    Please keep us posted on your progress, i have had this problem for as long as i can remember, i am going to do my glow plugs then maybe look at cleaning the starter. Good luck
    07 Jetta Tdi, DSG(tuned),Gtb1756vk turbo, 3inch dump, Malone tune, 4bar map, EGR+EGR Cooler delete, S3 Intercooler, Hard pipe kit, Gti rear sway bar, 18x8 Enkeii gtc01, nitto tyres, Rear Lip Spoiler, Votex Front Lip, Slotted and drilled rear Discs, Neuspeed springs, LED interior lights, Blackened window trims, Carbon covered pillars, Gti lower front Grill, canbus update, rcd510, tinted indicators, gti paddle shift wheel, soon to have Votex Side Skirts, Coilovers, Porsche Brakes,8mm wheel spacers, Alloy control arms, GTI front sway bar, S3 bushings....
    Dec 2014
    St Clair, NSW
    I have a feeling it is related to the starter and diesel injection. Just a hunch as it does everything else perfectly. I think it is starving of fuel due to the low crank rpm of the starter which i have read is a common problem when it is worn down. I think it could also be related to the injectors, they may be dirty.
    Aug 2013
    Production Automotive on Batt St in Penrith - I take my Polo there to get serviced, they are VW specialists.
    I Sell Nissans Skodas.
    IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
    R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
    Dec 2014
    St Clair, NSW
    Thanks Luke, Know about them from my air cooled vehicles. I did not know that they did watercooleds as well.
