I would have it checked out by a VW shop, that could become expensive.
Did they also do the water pump?
Our BKD went 200k before needing a water pump last month, but it could be a years of service thing as we are now over ten years.
Also in the BKD there's a harmonic balancer. If that fails, which is rare but happened to us when the water pump leaked coolant onto the HB causing the rubber to denature, the serpentine belt will go loose and you may get those noises.
