Results 1 to 4 of 4
Thread: MK5 oil leak
    May 2015
    Illawong, NSW
    MK5 oil leak
    Got an oil leak on my MK5 2.0L FSI.
    It appears to be seeping from the engine block just behind the oil filter. I'm guessing from what little I can see, that its leaking from the gasket between the engine block and the component that the oil filter housing screws into.
    Anyone "been there, done that" ?
    Apr 2015
    Brsbane QLD Australia
    Yes seen it a few times. Not a nice job, sure you need to remove manifold to get access. And sometimes the hosing cracks so best to replace the whole thing.
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
    Dec 2008
    Sydney/Canberra
    As per above.
    Also factor in a broken dipstick tube, and PCV pipes.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2015
    Illawong, NSW
    Thanks for the replies.
    I'm inclined to leave the fix to the experts but I don't have confidence in dealerships so I need an independent mechanic.
    Can anyone recommend one in the southern suburbs of Sydney? My search has come up with Bob Mol Motors at Caringbah. Anyone know of them?
