thanks for your replies @vinnY @sebas_thefish and the pictures/links posted
I'll be disassembling the damn thing on a weekend, will try to figure out if the key cylinder or the steering lock is faulty.
will post the updates.
nah my lock cylinder was fine, it was the steering lock portion that was jammed up(couldn't be turned with a screw driver)
I'll be popping on the lock cylinder to the new unit once it's here to test that it all spins okay before installation
shouldn't need any programming stuff, if it does I'll probably swap on my old ignition module since the centre section doesn't have any electronics
nope this was the one ordered this guy
cw.mkv.gti.034ms,s2+
On a previous car I owned [Polo 6N2] I had to replace the ignition switch @ around 145,000km & it was a pig of a job. I knew the ignition barrel was worn but it was still working but not smoothly. I was about to sell the car so I left sleeping dogs lay. It made me realize that the barrel needs to be lubricated occasionally. I would not use WD40 as when it dries it leaves a sticky residue. I use a Teflon based gun lube
that cleans, lubricates everywhere [it's very thin] & when it dries it leaves a Teflon coating on all surfaces.
Best Lock Lubricants for Locksmiths Review, WD40, TriFlow and Lock Saver | Mr. Locksmith Video - YouTube
Numerous Mk1 Golf diesels
graphite powder works well for lubricating things like key barrels without gumming stuff up
update, the steering lock finally did make it but it was jammed out of the box in a similar fashion to how my current one was sticking(only turning half way between off and acc)
managed to disassemble everything, thankfully only a handful of parts, and put it all back together after inspection and it seems to be working as expected
might check for debris on the old one and reassemble it all to see if it will function again, would save me from dealing with those shear bolts
little update, drilled 2 holes on the plastic surround that holds in the stalks and just chiseled out the shear screws with a flathead
installed the new steering lock unit with new m8x20 hex head bolts from bunnings and reinstalled eveyrthing in a matter of minutes
everything working as expected, no coding needed with the new ignition module
just reused my old key barrel and everythings happy
turns out a little tab behind the black plug broke off and jammed up the mechanism that stopped everything from turning
all is fine now though, cheap fix luckily
well done vinnY!
my update:
1. half day spent trying to remove the key cylinder from the barrel
used these 2 videos as reference but I just can't do it!
VW Golf 5 ignition lock cylinder removal - YouTube
VW Key stuck? VW GOLF MK5 How to Remove and Replace Steering Lock and key barrel - YouTube
got calluses on finger from trying different pins, paper clips and ****
going to locksmith tomo
yeah mine didn't line up perfectly, I had to back it off a little bit behind the dot
if you shine a light you can see when it becomes a cavity to shove the paperclip into
use a big paperclip if you can, not the smaller ones
I went to local locksmith and he managed to get the key barrel out of the housing somehow. I did hear some metal on metal whacking sounds tho. He said it wasnt possible to get it out due to that moving part not able to recess properly to let the key barrel out.
he did on the replacement housing+lock. To get the lock out of the old housing he suggested drilling a hole through the housing so that moving part could be pressed and recessed through that hole.
so I did that.
checked the old housing by trying to twist the ignition with flat screwdriver - it wasn't working, the old key barrel however was working fine on its own. So I figured the problem was in that housing.
however once I inserted my old key barrel into a new housing - I got the same problem! Both parts work when they separate, however wont work once inserted.
Going to check a few more things before ordering the whole damn thing off VW.
key barrel is ~370 and the housing is another 380 through VW dealership, I still have an option to order just the key barrel (after proving my car ownership).
will update on how it goes, however looking at all these videos and how other on internet able to sort that issue out - I either got the ****tiest end of all sticks or I'm doing something wrong which is also possible lol.
bad go mate, I did have a similar issue when I first got my replacement steering lock
tried to turn it with a screw driver and it locked up like my original one
I ended up disassembling everything to check it out, nothing looked out of place so I reassembled it all and it functioned as it should and is currently installed and functioning![]()
