Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Mk5 GTI suspension options
    Erskineville, NSW
    Quote Originally Posted by Bora Sport View Post
    So did you just buy the rubber insert? I have been searching EBay for Audi S3 LCA bushes and this is one that I came up with. I need to replace them on my wife's 125tdi Jetta but I want to upgrade. I assume they would be interchangeable with Golf GTI and therefore S3. I don't want to go to poly though. I tried to search the Febi number that you suggested but it doesn't look right. Maybe I'm wrong.
    Thanks for your help.
    QH Front Control ARM Trailing ARM Bush Lower Front RC677975P TO FIT Audi S3 06 | eBay
    That's the front bush. They usually last fairly well.
    Yes, just the insert
    Either this
    http://www.micksgarage.com/proddetai...id=1451234&pk=
    or
    Febi 33973 Control ARM Trailing ARM Bush Front Axle Left OR Right Rear | eBay
    or
    Control Arm-/Trailing Arm Bush 33973 from FEBI BILSTEIN - AUDI, SEAT
    Tooley, Imparts and HSY all do Febi. Give them a call.
    Munno Para West Adelaide
    When installing new suspension into the golf/jetta do you need to replace strut tops and bearings too like mk4s? Going to be putting coils in my mrs jetta soon
    Peregian Beach
    I'm going to replace the bearing part. The Mk 5"s are different from the Mk 4's. You can buy the bearing separately from the rubber top section apparently.
