Results 1 to 5 of 5
Thread: MK5 GTI spluterring under load
    Hi,
    Above car has just developed this fault. Seems to only happen when turbo is spinning. Also has been hard to start on colder days. Any ideas? Fuel injector stuck open? Fuel pump? Engine management light has lit up intermittenly when foot is hard to floor and spluttering. Also dual tail pipe looks unusually black ( not sure if this is linked). Have not noticed any excessive fuel consumption
    Thanks
    Chris
    Quote Originally Posted by Chucky007 View Post
    Hi,
    Thanks
    Chris
    I reckon you are over thinking this. Plenty of other explanations for your running faults. The first thing that should be done is a scan with VCDS, which will reveal any faults.
    Dec 2009
    Kew, VIC
    Plugs, coil packs, HT leads, fuel filter, fuel pump, injectors, carboned up manifold, low boost pressure (or none of the above.)
    In other words, have someone qualified check it out.
    Feb 2013
    east kurrajong, new south wales
    As already said a dtc scan will help pinpoint an area to start with.
    Mar 2013
    Brisbane QLD
    VCDS scan...if its putting the engine light on then it should be logging a code...hopefully a cylinder detection misfire code to give a good starting point...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
