Nice to see a build thread on here! Good luck with it all.
My 2c: spend a bit more on some name-brand coilovers or suspension kits if you can. You'll need to replace most of the suspension bolts and nuts with new ones, since most of them are torque-to-yield and won't be safe to reuse once you've taken them out; it makes it worth getting some decent components the first time. I run AP coilovers on my mk5: Buy AP Suspension Coilover Kit - GF10-040 | Demon Tweeks - they're only a few hundred bucks more than eBay suspension, and the ride/handling balance is incredible for the price. Vogtland is another super well-reviewed cheap brand if you want to go lower.
I also spent another ~$400 on new high-density strut mounts and bearings, which you'll probably want to do if your car's around 150k kms - also makes the install way easier since you don't have to disassemble the old units.
In terms of tunes: I run a stage 1 Superchips tune on mine, which is probably the cheapest way to get more power out of an FSI engine (about $400 shipped for a DIY tuning unit). I'm about to jump to stage 3 with them with a K04, but wouldn't recommend them for stage 2; some people have issues with misfires and fuelling. Revo's meant to be good, and cheaper than APR.
