Results 1 to 5 of 5
Thread: MK5 golf rear speakers
    Dec 2014
    Perth, WA
    Hi,
    Im looking at installing a subwoofer and i was wondering if anyone knew where the most rear speakers were that aren't placed in the doors. Im wanting to connect a line level converter onto that speaker and run it to my amp to give signal.
    any help would be great, thanks,
    swenet01
    Sherwood, Queensland
    Hi swenet01,
    The rear doors would be the closest point as the stock amp location is under the passenger seat
    Tony Mickel
    Dec 2014
    Perth, WA
    Quote Originally Posted by kane9522 View Post
    Hi swenet01,
    Tony Mickel
    Thanks Tony!
    are the cables labeled on the amp? is the amp under the carpet? and finally, i have 5m of RCA in my wiring kit, if i was going from the amp to the boot, would that do fine?
    Thanks in advance, a real big help!
    Swenet01
    You would know if you have the stock amp already - 3way speakers in the front doors, and it sits on the carpet, so you would see it.
    5m of RCA would certainly go from under the passenger seat to the boot
    if you have not already seen these, then i would suggest getting one, they make the process so much easier
    ISO SOT 8502 N Lead Cable Adaptor FOR Parrot Volkswagen Fully Populated | eBay
    Inka 044 9979 2 5M Twin ISO Extension Parrot MKI9200 | eBay
    Dec 2014
    Perth, WA
    It's fine, i got it all to work, i found a wiring diagram (i can link if anyone needs) that told me what wires to strip in the main loom down the trims. I used the 12v accessory port in the boot for the remote, and the ground near the rear light. All works well and sounds great!
