That is not the fuse panel you are looking for.
You want the cabin fuse panel which is in the end of dash board drivers's side when door is open.
Check this site, seems to cover it well. Fuse box Volkswagen Golf MK5
Recently picked up an MY09 MK5 GTI Pirelli Edition which has plenty of issues I'm trying to work out, the main being multiple light unit failures. I currently have the following positions out which are not remedied by new bulbs (after switching in bulbs that are currently working, or new).
Drivers side low beam
Drivers side high beam
Drivers side rear indicator
Drivers side rear brake
Drivers side inner rear driving
Drivers side reverse
Passenger side fog light
Passenger side rear brake
Passenger side outer rear driving
As most of the issues are on the drivers side I'm assuming a fuse is out, although I've already checked the engine bay fuse box and visually can't see any blown. Will pick up some replacements and test anyway.
In the mean time, it would be helpful if someone could check over the image of my fusebox and advise if there's any missing / wrong amperage? I've checked the owners manual and a few online resources but "Depending on the version and specifications of your vehicle, the fuse numbers and positions may differ to those given in the table" has me concerned as they don't align 100%.
Thanks in advance!
Fusebox — imgbb.com
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Thanks JustCruisn - managed to solve it with new fuses, it was actually the engine bay fuse box.
In case it helps anyone in the future, looking at the image in my original post it was a 30amp fuse at the very top right of the fusebox, above the yellow 20 amp. If you have an issue with multiple bulbs out at once, it's possible this fuse is burnt out. I ended up finding similar advice on other forums as well, which is reassuring.
