Originally Posted by
datracer99
If you have a problem and the delaer won't replace under warranty then get an inspection from your state motoring association (NRMA, RACV etc) before the warranty expires.
highlight the things you know are a problem, and make sure they list them on the report.
That way, if the part breaks soon after warranty expires you can take the report in and show them that it had problems before the end of the warranty.
This is especially worthwhile if you have intermittent problems, as I did this with a 2nd hand car in the past and got the dash replaced after the warranty expired.
Depending on the issue it may not always work, but is worth a try.
