Page 7 of 33 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 329
Thread: Mk5 Golf/Jetta Problem Registry
  1. #61
    Mar 2007
    Hitlon WA
    Quote Originally Posted by datracer99 View Post
    If you have a problem and the delaer won't replace under warranty then get an inspection from your state motoring association (NRMA, RACV etc) before the warranty expires.
    highlight the things you know are a problem, and make sure they list them on the report.
    That way, if the part breaks soon after warranty expires you can take the report in and show them that it had problems before the end of the warranty.
    This is especially worthwhile if you have intermittent problems, as I did this with a 2nd hand car in the past and got the dash replaced after the warranty expired.
    Depending on the issue it may not always work, but is worth a try.
    Thank you for that info
    I will find out if it is possible in WA
    GOLF V 2.0 TDI COMFORTLINE
    SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
  2. #62
    I've had a blown right front speaker from new. Extremely annoying.
    Noticed a wierd noise from the drivers side window when going down in the last say 10-15cm.
    Thinking they might have just left a screw out of the speaker when the tint was done. Surely it can't be be a blown speaker from new when it's supposed to be a premium sound system.
    MY08 2007 Tornado Red MkV Golf GTI DSG 5dr Anthracite Leather RNS-510
  3. #63
    Aug 2007
    Blue Mountains
    Quote Originally Posted by GermanwithaVdub View Post
    no that i know of, but ill give you a few things to consider:
    1 -definitely get this activated- the auto dip left mirror when you put it in reverse. not only does it make reverse parking easier, it'll also save your wheels if you're prone to scratching them (mine still scratch free at 10000km )
    I have had most of the convenience options I wanted set by the dealer free of charge and without argument. Thanks to everyone who said I shouldn't have to pay
    My car doesn't have the option of the auto dip left mirror and
    How can this be given everyone else seems to have it? The car was manufactured in Nov 06 and is the 2007 spec. Any clues as to why they could not find the option?
  4. #64
    Albury, NSW
    Quote Originally Posted by Spoddy View Post
    Don't worry about missing out on the mirror dip....I sat thru the VAG-COM thingy the other day with my dealer and my R doesn't have the option ('07 model, '06 complied)
    Blue MkV R32 3Dr, DSG, Sebring box & 2.5" stainless, BMC CDA CIA + 3.5" stainless, 18" O.Z. Ultraleggeras, H&R springs, carbon rear valance
  5. #65
    I can't work out how to activate the reverse mirror dip on my MY08 GTI. Looked through all the menu options......Anyone know how to do it ? Is it definitely possible ??
    Sorry just seen this thread. Should have searched beforehand.
    See Here
  6. #66
    Aug 2007
    Kew, VIC
    Dip Mirror - EXPLAINED
    Quote Originally Posted by THE KOP View Post
    See Here
    I beleive the dip mirror thingy only works if you have Parking Sensor.n:
    On my GTI with parking sensor it works - my mates GT with no parking sensor don't work...
    Hope that's cleared up.
  7. #67
    Albury, NSW
    Quote Originally Posted by Uomo View Post
    That's the most logical answer we have had yet. Even the dealers cannot to us that!
  8. #68
    Mar 2007
    Canberra
    Oil leak
    Just thought that I'd give an update on my continuing oil leak problem.
    The VW service department now have a new rocker cover on order from Singapore ( go figure ). Apparently the current rocker cover is warped which is why the previous gasket replacements didn’t stop the oil leak.
    Anyway, time will tell if this is the real culprit.
    Cheers,
    JP
    2010 Tiguan 125TSI
    2004 Polo Match
    1976 White MkI Golf
  9. #69
    Had the problems sorted.
    Both were related to and extra piece of trim left inside the door (Dealer said it was left in there from the factory, my feeling is that the piece was left in there when the tint was done).
    All fixed so don't care either way I suppose.
  10. #70
    I had a wierd thing happen the other day to my GTI.
    I locked it up and went away, when I came back the windows were all down and the hazard lights were flashing.
    I can put the windows down to the remote being depressed in my pocket and held down I guess, but the hazards flashing?????
    It has not done it since and I can't seem to replicate the error. Any thoughts?
