Page 30 of 33 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 329
Thread: Mk5 Golf/Jetta Problem Registry
  1. #291
    Apr 2009
    I just got a 05 GTI, car is in such good condition! One owner, drives beautifully like a brand new car BUT my clutch is sticky.. like once I've changed gears the pedal doesn't bounce back to full extension straight away and sometimes i actually have to physically put my foot under the pedal to push it up.
    Anyone know what it could be and how much its going to cost me?
    I purchased the car last week.
  2. #292
    Jun 2008
    Ringwood East, Vic
    2006 Jetta 2L turbo
    -Climate control seemed to stop working. Essentially next to no air was flowing out of any vent on any mode after working fine for a couple of hours. Ambient temp around 28 deg. The fan was working - you could hear it increasing and decreasing first of all as it tried to cool the car down then later on stuffing around with it.
    I pulled the pollen filter out and the fan was blowing properly... I guess there is some sort of solenoid or vaccuum operated thing to switch the airflow between the different modes which was stuck in a closed position which sits after the pollen filter.
    After turning the car off for lunch then starting it again 1 hr later, it was fine.
    Same thing happened after 2 hrs driving a couple of days later.
    Has anyone experienced anything like this.... and more to the point, have any ideas how to fix it?
    Dan
  3. #293
    Mar 2012
    Sydney NSW
    question
    mkv gti - when aircon is ON (not seemingly econ) there is the occasional muffled " tap tap tap tap tap tap tap" in the dash area...i THINK it arises when the aircon first goes on (climate control ?!)
    Any ideas ?
  4. #294
    Mar 2007
    Hitlon WA
    I have no problems with mine any more, not that I had many at all
    Traded it in for new VE Commodore Equipe..Sad a little but happy with new car.
    GOLF V 2.0 TDI COMFORTLINE
    SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
  5. #295
    Dec 2007
    Quote Originally Posted by bennjamin View Post
    question
    Any ideas ?
    I believe this is the fan shifting between outlets - the little switch on the vent on top of the dashboard is to the right - does it go away when on the left?
    Gone: 2009 MkV GTI DSG United Grey; 2005 MkV Comfortline
    Current Rides: 2020 Mk7.5 GTI Performance ; 2013 MY14 V6 Touareg 180TDI
  6. #296
    Nov 2009
    question
    Any ideas ?
    This is the motor inside the vent very common problem. You need to get it replaced or it will always make the noise.
    Volvo S60 RD T6
  7. #297
    Mar 2012
    Sydney NSW
    Quote Originally Posted by thezoneR32 View Post
    thanks for that - a couple of google searches give me the same issue- its a pita to fix apparently.
    This issue isnt constant - seems to stop when AC is off (in economy mode) or induction is on etc. Its a sticking part in the motor ?! Once it drives my gf mad i will replace it.
  8. #298
    Mar 2008
    western sydney
    my golf gt tdi wouldn't start this morning.
    not sure if its the battery as it only replaced <12 months ago.
    as soon as you turn the ignition on to the glow plug stage you hear this really fast click click click clicking noise and nothing rolls over when you try and start it all the way...battery or something else??
  9. #299
    Sep 2007
    Coorparoo QLD
    In two weeks I will have owned my Jetta TDI for five years (82,000 km). The first 4.5+ years were good but the past couple of months have been terrible.
    The first problem was leaky seals in the fuel pump, then came the solenoid for the fuel filler door which was closely followed by the driver's door actuator. Finally, the roof lining started pulling away from the overhead console and the passenger side A pillar.
    The lining, in particular, was really disappointing. I thought that only happened to old Hyundais.
    In fact, a new Hyundai is starting to look pretty appealing at this stage.
  10. #300
    Mar 2009
    Brisvegas
    The driver's seat lumbar support no longer winds out to provide adequate lower back support.
    This was an important feature at purchase for this older Dubber
    We asked about it at the 75,000 service and it is being replaced under warranty, so all good.
    MY09 Golf Candy White 2.0 TDI Pacific
    MY95 Golf III TDI
