Wheel bearing replaced (it was making a clunk sound) and new rear shock absorbers needed (front ones recently replaced) 2006 GTi with 70k on the clock. Does that sound a little early for shock absorbers to fail?
my car threw a steering angle sensor code and it came up with a ram module error?? wtf? anyone had this issue?
tried clearing it using vcds and it didnt go away, so im guessing it could be something serious.
84 MK1 GTI
01 DC2R
I found that the engine of my 2005 1.9TDI was getting sluggish to start when the engine was hot.
If it was left to cool down about 2 hours then it would start basically normal.
At 90000Km the starter motor needed replacing, as the car was over 3 years old - no warranty- had discussions we dealer & VW Aust & the final cost was I had to cover 25% of the cost .About $420
Since then I have heard that a neighbor of a work mate has the same fault.
Any others around having the same issue
I went out for a quick drive around this afternoon and have noticed this tractor like noise coming from engine bay area. It lasted about 10 seconds before it disappeared and it was consistent regardless of whether the aircon was on - it was always there as I was slowing down and slowly accelerating, and even at stand still at the lights. The noise was more prominent from inside the car and could not first identify it when I tried to hear it from outside the car. The car felt like it lost a bit of power too. Standing in front of the engine bay with the engine running, the noise seemed to be coming from left hand side of the engine where I saw a black belt. Does anyone have any idea what this noise might be? The car has had a 45k service only recently. I had this very similar noise in my old car before where the oil and filter changes were well over due and the noise was gone after servicing.
During a the scheduled 30,000 km's service I was advised that they had found some oil leaks on side of the engine. Was advised it was nit major and as I was going away on a trip that weekend should be ok to take it.
Took car back a week later for further inspection and was told that leak was from Turbo?? Turbo replaced under warranty. However after replacement I now has a whining sound at low rev's 1000-1500 rpm (i.e in traffic etc.)
Car goes back for more inspections and was told some alignments done, problem still remains. Car goes back again and a guy from VGA come out to inspect it.
I am told that the noise is within specifications, however if i wish they will replace the turbo again on the condition that if the noise is still there better or worse no more work will be done on it ..
I am now due back in about 10,000 kms for it's 60,000 km service. The noise is still there and I have some decisions to make :-/ Car also seems to have lost some of it's top end power.
I have had two rattles repaired one on the drivers door and one on the passenger front door.
I now have one coming from somewhere near the steering column, I suspect one of the air con vents ??
Also my DSG seems to have an issue whereby every now and again it makes a clunking sound on take off from a stand still.. almost like it misses the gear and then drops in again.
2008 Golf V Comfortline 1.9 TDi DSG Black S/roof
Have to say, if these are the worst problems, I can't wait to buy my V Jetta. I've had Magnas since 1996 and a trouble free run - hoping for the same with VW.
MY07 Jetta TDI
EGR valve replaced at around 45,000 on a BKD engine under warrant (apparently it tore, I never noticed. Dealer identified by oil leak at service).
Drivers door lock module replaced at 65,000 under warranty as it wasn't unlocking the door anymore (but the key still worked).
Otherwise flawless.
Any chance of a pic showing where that harness is?
I've had a look and none of the harnesses look like they're too short.
Mine's a MY07 (not a Sport) so may have any original 'faults'.
I haven't had any problems, but as the car is getting towards the end of its warranty (July), I'd like to have any issues like this fixed before then.
cheers
2007 Golf GT | DSG | TR | roof | iPod rubbish | R line fog grilles | R satin mirror caps | R pedals | R console trim | colour coded GTI valences | R32 Ormanyts
I have a 05/05 plate Golf 2.0 FSI and it has developed a problem.the problem is with the NOX sensor after the cat VW part # 06F907807 F. i went to VW and the price is $1200 with a little change
The car is running ok at the moment so i hope it makes it to tax time..
Fastest
I beleive they have me by the short curly ones
2005 Golf V Comfortline 2.0 FSI, Black, 6 Speed Manual, Leather, Sunroof
that sounds well expensive.
Look for the part online considering you have the part no.
Try 1stvwparts or something similiar.
