Page 9 of 33 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 329
Thread: Mk5 Golf/Jetta Problem Registry
  1. #81
    Point Cook, Vic
    yeah i think the rain sensor likes to have a clean windscreen. Im horrible at keeping my cars clean and i get a random swipe every now and then too.
    One weird thing i have had a few times is a random wipe when i go under etag sensors on tollways. I dunno if its just co-incidence. but yeah good timing if it was.
  2. #82
    Mar 2007
    Hitlon WA
    automatic wipers
    Well.
    Next day I left windows slightly open on 37C heat and wipers were OK....
    I still think that it has something to do with a heat that day
    GOLF V 2.0 TDI COMFORTLINE
    SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
  3. #83
    Aug 2007
    Blue Mountains
    The fog lights have gone foggy and the cost of a 15,000km service for a 2.0 TDI
    Has anyone found that over time the glass on the fog lights get some sort of film buildup on the inside? doesn't look like moisture as usually you see condensation droplets, this is just a opaque film.
    One more thing for the first service....
    Quote given is approx $360. Is this normal?
    SPoddy
    2020 Tiguan 162TSI R-Line
  4. #84
    Mar 2007
    Hitlon WA
    Quote Originally Posted by Spoddy View Post
    Mine was that much... It sounds OK
    Edit
    Guys, how is your climatic air con when set at 22?
    cold, moderate or warmish?
    I need to know because I have a feeling that mine could be slightly empty (leaking gas) in spite being used to heat in winter and colling in summer (got the car and Feb 07)?
    Used it just about every day but when 38 outside it doesn't seem to cool the car when fan speed set at 1 or 2? when changing temperature down to 20 I don't notice much of a difference unless I set a fan speed at 3
  5. #85
    Sydney,NSW
    Mine feels slow to cool down, but...
    Do you have the centre windscreen vent turned on? If so, turn it off & see how cold the air is coming out of the dash vents.
    The centre vent sucks a lot of the cool air, so it doen't seem to be doing much. I turn my centre vent off for 5 minutes to cool things down, and then turn it on and let the auto system take over.
    07 Golf GTI 3 door, Tornado red, 6 speed Manual
    Red may be the devils colour, but this car is pure heaven
  6. #86
    Mar 2007
    Hitlon WA
    [QUOTE=datracer99;104848]Mine feels slow to cool down, but...
    QUOTE]
    No I don't.
    It is set to blow straight to your face
  7. #87
    Aug 2007
    Blue Mountains
    Ours has always been warmer than the set temp. We run ours mostly on 19.5C whereas in the Kluger we run 24 otherwise we freeze.
    We have the centre diffuser (top of the dash replacing the shelf tray....) it is meant to cool the car quicker from start than the straight vents but I only notice it is quieter that way.
    SPoddy
  8. #88
    Jun 2007
    Chatswood, Sydney
    lets not mix up climatic and climatronic... the climatic doesnt have the centre blower, it has a small tray for a wallet or phone, it also only has the twisty knob to adjust the temp, with no digital displays... the climatronic is the one with the centre air vent thing in place of the tray, plus the 2 zones plus the digital setup.
    on my comfortline (with the climatic), when set at 22 (dial facing straight up) it seemed moderately cold
    New user account: Mischa
    Have: gt sport tdi, mk2 gti, mk1 3dr
  9. #89
    Nov 2005
    here and there
    Rcd300
    Hi
    today i noticed that my RCD 300 head unit has lost its ability to shuffle (mix) both CD tracks and Ipod tracks. VAG com shows no fault with the unit, and all other functions are ok... i will book it in for a check up. any one else experienced this?
    thanks
    (maybe the Golf knows it is being sold soonish, and this is a protest?? )
    VAG-COM
  10. #90
    Dec 2007
    Our 2005 has had a couple of issues, all fixed FOC.
    1. Remote mirror adjuster fell into door - fixed under warranty.
    2. Rattle from boot - worked out it is the little rubber knobs on the end of the rope that holds the boot cover - anyone know a simple fix to stop this - we have millions of speed bumps in our area and it's pretty annoying. I think someone else mentioned this an earlier post but thought it was the actual shelf.
    3. Sluggish gear changes - update to gearbox program at service. FOC.
    4. "Rattle" in Cat converter (noted by dealer at 2yr service) - replaced under wannanty.
    Oh, and we paid $330 for 1yr service (someone wanted to know if $350 odd reasonable), closer to $550 for 2yr (with brake fluid change).
    Climate control works fine set to 22deg (comfortline spec).
    Also, can anyone shed more light on what "options" (mirror dip etc) are possible to be enabled? Is it only on GTI or on any MkV?
