Ignoring the problems, take it for a drive.
You'll soon know.
You'll soon know.
hey guys
my accelerator pedal make clicking noises when pressing for acceleration and de-pressing for deceleration.
Anyone has experienced anything similar?![]()
GOLF V 2.0 TDI COMFORTLINE
SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
Kick down button
Prev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
anyone else get twang noises from under their car when coming to a stop?
and a knock under their feet?
theyre getting annoying would like to throw some suggestions to the dealer when i book it in for an inspection
GTI 2006 DSG
Drivers side door rattle - ? loose door speaker , and upper door trim loose.
MKV Red Golf GTI
During a the scheduled 30,000 km's service I was advised that they had found some oil leaks on side of the engine. Was advised it was nit major and as I was going away on a trip that weekend should be ok to take it.
Took car back a week later for further inspection and was told that leak was from Turbo?? Turbo replaced under warranty. However after replacement I now has a whining sound at low rev's 1000-1500 rpm (i.e in traffic etc.)
Car goes back for more inspections and was told some alignments done, problem still remains. Car goes back again and a guy from VGA come out to inspect it.
I am told that the noise is within specifications, however if i wish they will replace the turbo again on the condition that if the noise is still there better or worse no more work will be done on it ..
I am now due back in about 10,000 kms for it's 60,000 km service. The noise is still there and I have some decisions to make :-/ Car also seems to have lost some of it's top end power.
I have had two rattles repaired one on the drivers door and one on the passenger front door.
I now have one coming from somewhere near the steering column, I suspect one of the air con vents ??
Also my DSG seems to have an issue whereby every now and again it makes a clunking sound on take off from a stand still.. almost like it misses the gear and then drops in again.
2008 Golf V Comfortline 1.9 TDi DSG Black S/roof
Have to say, if these are the worst problems, I can't wait to buy my V Jetta. I've had Magnas since 1996 and a trouble free run - hoping for the same with VW.
MY07 Jetta TDI
EGR valve replaced at around 45,000 on a BKD engine under warrant (apparently it tore, I never noticed. Dealer identified by oil leak at service).
Drivers door lock module replaced at 65,000 under warranty as it wasn't unlocking the door anymore (but the key still worked).
Otherwise flawless.
