Results 1 to 7 of 7
Thread: Mk5 golf fsi and GTI Actuator Mechanism
    Apr 2013
    Hi, I have to buy two of these Actuator mechanisms for my GTI. Need to know if they are the same as the FSI model.
    I am aware that the right and left side of the car is different.
    Thanks
    May 2016
    Melbourne, Victoria
    Which actuators are you referring to? The door lock actuator or something else? If its the door lock actuator then yes they are the same across all mk5 Golf/Jetta.
    Apr 2013
    the door locks
    Mar 2009
    Goulburn NSW
    yep they are the same. check your door wiring harness as well when you pull the door apart (between the door and the A pillar)
    Apr 2013
    Got some new locks on eBay will be checking the wiring too. thanks for your help.
    Mar 2009
    Goulburn NSW
    Dont throw your old ones out. The most common fault is the micro switches failing and the motors filling up with gunk. The switches can be replaced and the motors pulled apart and cleaned. It’s a bit of effort but some people say the Chinese ones don’t have a great life span so might be worth fitting them and then rebuild your old ones to refit when the new ones fail.
    Apr 2013
    ok, will do.
